Rex wrote:Here's a little background on Series & Parallel:
* Series - A configuration in which a single current path is arranged among all components. Connecting the positive speaker output of an amplifier channel to the positive terminal of speaker # 1 , connecting the negative terminal of # 1 to the positive terminal of speaker # 2, and the negative terminal of # 2 to the negative output of the same amplifier channel is a series connection.
* Parallel - A configuration in which the same voltage is applied to all components, with current divided among the components according to their respective resistances or impedances. Example: All positive leads of two or more speakers connected together and all negative leads connected together.
* "Pro's & Con's" ... hmm that's hard to say. The main purpose is to adjust the "load" the amplifier sees. Most car audio amplifiers are designed to operate between 4 and 2 ohms. Some "high performance" amps are designed to run at 1 or even 0.5 an ohm. By using series, parallel or a combination of both you can create the ideal "load" for the amp to see/perform.
I know that's a quick overview, but it should help get things started.
<anymore questions, just ask. We'll help>
I'll work on adding in the diagrams.CarStereo wrote:
A trick that professional installers use to get more power out of amplifiers is to wire up speakers in different ways, playing with resistances to achieve a desired total impedance "seen" by the amplifier. Even though speakers are active loads (resistance changes with frequency), it is accepted to treat speakers as resistors with a fixed resistance value (usually 4 ohms).
By combining speakers in different ways, maximum amplifier output can be obtained. For example if a 2-channel amplifier is rated to deliver a maximum output of 400 watts at 2 ohms mono (bridged), then by hooking up two 4 ohm subwoofers in parallel, a total load of 2 ohms is "seen" by the amplifier, obtaining optimum power.
Parallel Resistance
Parallel Wiring Diagram
People commonly hook up two or more speakers to the same channel out of an amplifier in parallel. This is achieved by hooking up the negative wire from the amp to all the negative connections of the speakers, and the positive to all the positive connections of the speakers. By doing this, the load seen by the amplifier is lower. For example, if two 4-ohm speakers are wired-up in parallel, then their total resistance will be half, or 2 ohms. If three speakers are wired up in parallel, and they all have the same resistance value, then the total load would be a third of the value of each speaker's resistance. Here's a formula to calculate parallel total resistance for two speakers:
Parallel Resistance Formula 1
For more than two speakers, use the following formula:
Parallel Resistance Formula 2
So what are the advantages and disadvantages of this scheme? First, if one of the speakers burns out, then the other one(s) keep playing. If the amplifier is not designed to receive lower loads provided by hooking the speakers up in this fashion, you might end up destroying your amplifier. Check your manual or consult an expert.
Series Resistance
Series Wiring Diagram
Speakers are hooked up in series to decrease total load to an amplifier. To hook up speakers in series, connect the positive terminal of the amplifier to positive of one speaker, then hook up negative of that speaker to positive of next speaker, and so on. Then hook up negative of last speaker to negative of the amp. It is a lot easier to calculate total resistance for speakers hooked up in series. This is easily done by adding up all the individual resistances:
Series Resistance Formula
The disadvantage of hooking up speakers in series other than getting less power out of an amplifier, is that if one of the speakers burns up, the other one(s) stop working.
Do what? I have never seen a 4 channel amp that would allow you to bridge all four channels into one.PoorManQ45 wrote:If it was a four channel then each channel would see 1/4, or two ohms.
I've seen a few before, but can't recall the brands. I was just giving an example BTWaudtatious wrote:Do what? I have never seen a 4 channel amp that would allow you to bridge all four channels into one.
Thanks, I was actually thinking about my mistake the other day, but I never got around to correcting it.audtatious wrote:In this scenario, he will be running a 8ohm load to the amp. The amp is rated at a certain wattage @ 4ohm bridged. He will be getting 1/2 that power running the sub in series.
I have never seen one either.audtatious wrote:Do what? I have never seen a 4 channel amp that would allow you to bridge all four channels into one.
Have you actually done this before? Ive read that you can and that you cant.I dont know who to believe.Dj Dingo Murphy wrote:bridge 4 channels to 2. Wire one set of bridged channels to one coil, and the other set of bridged channels to the other coil. Rock and roll
