Rex »
https://forums.nicoclub.com/rex-u6324.html
Sat Jan 01, 2005 1:21 pm
The things you're seeing can be attributed to an alt going bad. One simple thing to do, is park facing a wall at night and see ho much the lights dim at idle, or brighten when you raise the idle by giving it a little gas.Also, are you seeing the lights start to dim when sitting at idle and the bass thumping?
How old is the battery? Replacing older batteries before they die can save alt's from undue wear and tear.
Depending on your locale the current cooler weather could be adding additional load on your battery (and thusly on the alt) as well.
