jacamania wrote:Hi Guys, just bought a QX50 a few weeks back. We have owned two hatchbacks before this, a Mazda3 and a GTI. I love the QX50, but one thing that kind of bothers me a little is that compared to the two hatches that we had, the QX50 seems to require quite a bit more force to close the hatch for it to shut completely. Just wondering if anyone has every felt the same way and if there is anything that I can do.
I had the same issue initially when I switched to the QX50 from a Mazda CX-7. But that's because the QX50s hatch is light/easy to move that when you close the hatch you get tricked into using less force when closing. I've since learned to give it a little extra oomph right before I let go when I shut the hatch. Otherwise it has less inertia to close.
Semi nerdy explanation: Door is lighter, you need less force to move it and with less initial force, you have less inertia for the door to follow-through and shut completely.
