Cobra_Kai_84 »
https://forums.nicoclub.com/cobra-kai-84-u143986.html
Fri Sep 03, 2010 5:47 pm
I live in AZ. My temp gauge always reads a much higher temp than it actually is, especially when its really hot out (4 months of out the year). Mine is typically 6-10 degrees off, regardless if the car is parked in a garage away from the sun. I mentioned it to my service guy when I brought the car in for an oil change. They said Infiniti allows for a "10%" standard deviation, so there is no reason (in their mind) to replace the gauge since it falls under that 10%. They said it's not faulty and nothing is wrong with my outside temp gauge. They ran my car next to another convertible at the dealership, and both were reading very close, albeit higher numbers than actual temperature.
It''s really a nitpicking thing. Personally, it bothers me. My service guy said that if I want to replace the temp gauge they will do it, but should probably expect similar readings. I may have them replace it next time I bring my car in. Why not? Anyone else getting high outside temp readings??
