Ambient Lighting
buddyle23
Car: 2011 Nissan Altima SL, 08 Honda CR-V EX, 11 Nissan Rogue SV AWD, 04 Honda Element EX
Is there any easy way to install footwell ambient lighting like in the Sentra or Civic? You can get it as an option on them. I know the Escape also has this option as an accessory as well (to compare something in the same crossover category). I'd think it look cool with orangish red lighting there.
Modified by buddyle23 at 1:16 PM 8/7/2009
zengshengliu
Car: 2008 Nissan Rogue SL
Led strip light can do ithttp://www.v-leds.com/Strip-Li.../truebut the only problem is you have to find a place to wire itAlso, it only has white, blue, and red for the color
Edited: Just saw that they have amber color for the 12 inches one
Modified by zengshengliu at 6:43 PM 8/7/2009
philipa_240sx
Speaking of lighting, I miss the courtesy lights the Altima had. They were located on the bottom edge of the door and illuminated the footwell when the interior lights were on or when the door was opened, the ground around the door.
Elton Noway
Car: 2009 Rogue SL FWD Phantom White Black Cloth
buddyle23 wrote:Is there any easy way to install footwell ambient lighting like in the Sentra or Civic? ... I'd think it look cool with orangish red lighting there.
Sure ... its not all that hard. Most LED light kits are pre-wired. Simply place the pre wired LED light strips up under the dash shinning down and under the seats shinning out. With these kits, all you need to do is find a 12V source under the dash (usually at the fuse block) and tie into it. You can either mount a SPST remote switch under the dash within easy reach... (or a little trickyer) tie into the existing interior light circuit so they come on when you open the door. Run the wires under rocker panel molding and carpeting.
While LED light strips are pretty easy to find, LEDGlow and Fyre Flys have made a good dent in cornering the LED interior accent lighting market. here are plenty of LED light strips on the market...
LEDGlow http://www.ledunderbody.com/le....aspx
Fyre Flys: There are several suppliers of Fyre Flys light stips but probably the best selection... all in one place... is one eBay:
http://stores.shop.ebay.com/Fyre-Flys-LED-Shop
Pescakl1
Car: 2008 Nissan Rogue SL FWD
Iridium Graphite
Here some other references which are highly regarded in a specific LED forum:
Quote »Search ebay with these terms "Fantastic wide viewangle cluster 8pcs" to find them. Be sure you get the wideangle and not the narrow angle. ...Don't choose the 3chip-3-LED versions as they have flickering issues sometimes.[/quote]If you prefer to deal with an american company (same products), here another ebay store selling these LEDs: http://stores.shop.ebay.ca/FCB...em322
The good thing with these is they have mounting holes to install them in the car. They seem really reliable, more than most led strips sold on ebay.
zengshengliu
I had ordered the blue strip lights from v-leds and should be here by wednesdayI will post some pictures as soon as I got it installed
Modified by zengshengliu at 3:35 PM 8/10/2009
Elton Noway
Pescakl1 wrote: If you prefer to deal with an american company (same products), here another ebay store selling these LEDs: http://stores.shop.ebay.ca/FCB...em322
FYI: The above referenced link will direct you to sellers store via eBay Canada. If you need (or prefer) to access his eBay US store you can follow this link:
http://stores.shop.ebay.com/FC...l1198
Nick 568
zengshengliu wrote:I had ordered the blue strip lights from v-leds and should be here by wednesdayI will post some pictures as soon as I got it installed
Please do, I've been thinking of adding these myself. Something other than the little hole with the orange light in the ceiling which Nissan calls mood lighting, lol.
takeshi
Car: 2008 Nissan Rogue SL AWD
Nick 568 wrote:Something other than the little hole with the orange light in the ceiling which Nissan calls mood lighting, lol.
I actually find it very useful. Provides good lighting of the center console at night without too much or too harsh a light.
zengshengliu
Here you goAll are 12" blue strip lights from V-Leds
Here is the light I put in earlier, and is connected to the from map lightThey are 48" white strip lights from V-Leds
rjchoops
Car: 08 Rogue SL AWD
LOOKS GREAT! Do you leave the blue ambient lights on while driving?
zengshengliu
rjchoops wrote:LOOKS GREAT! Do you leave the blue ambient lights on while driving?
I might when I am driving at nightbut I didn't try it yet as I just installed it last night
Nick 568
Wow, that does look good! Tempts me to get lighting for the rear seats too. Probably won't though, seeing as how I don't often have people in the back seats.
buddyle23
Did you just plug it into the front plug then?
zengshengliu
NoI have a GPS, a radar detector that need powers so I buy a 3 way split with on/off switch which you can see from the picture. I connect all the lights to the third switch and hide all the wires for it so all you can see is lights
Return to “Rogue Forum”
