It's a balance-resistor setup (voltage divider). There's a fixed pull-up resistor to 5V in the cluster, then the sensor acts as a variable pull-down. Ohm's Law determines what voltage exists at the junction, V = 5V * (1 / ((fixed + variable) / variable)). The sensors are all NTC (resistance drops as temperature rises), so grounding the input will pull it to 0V and make it read max hot, opening the circuit allows the fixed resistor to pull it to 5V and it reads max cold. That's why crossing the broken leads will effectively test the circuit. We actually see a lot of A/C problems caused by those types of sensors in Auto A/C systems. When they fail open-circuit the car thinks it's in Alaska and won't turn on the compressor.GreenGiant14 wrote: ↑Wed Mar 16, 2022 3:00 pmI ordered the sensor plug on amazon.com. was 28 CAD with exchange. Right now it reads -30°C. Been like it since the fall
