rrobe99999 »
https://forums.nicoclub.com/rrobe99999-u11731.html
Fri Dec 05, 2003 6:10 am
I have a '95 240SX that I bought with an S14 SR20DET already swapped in. There are a few things that were not completed. The A/C only blows cold air, and the compressor does not cycle off. I cannot adjust the temp, and now I want hot air. I found the ambient air sensor behind the front grill. It reads as a short with my ohm meter. I took it out and heated it with a hair dryer, and did not get any different resistance. Is that good or bad? If I disconnect it, the A/C still runs the same. Is there a cabin temp sensor I should check out? TIA for any advice that will help me fit this problem.
