Amber 4WD on, blanked display (Xterra 2012)
Nissan Uncle
Car: 2012 Nissan Xterra
On my Nissan Xterra 2012, the 4WD light is on. The associated display is blank.
My mechanic tried to retrieve data from the test plug, but no stored faults were associated with AWD.
My Nissan was on the hoist, and we couldn't find any clue what the root of this failure could be.
Could it come from the selector? If there are no stored faults, I assume there is no computer for 4WD control.
I'm open to any suggestions or ideas you may have. What do you think could be causing this issue?
I appreciate your time and engagement to help me.
Thanks,
Matt
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There is a transfer C/U and it should be on the CANbus. Check fuses 57 and 58 for power and make sure they aren't blown. If they' have no power, check Xfer Shutoff Relays 1 and 2, one of those is probably bad. See PG-70 here:
https://www.nicoclub.com/service-manual ... 2%2FPG.pdf
Nissan Uncle
Dear VStar650CL, Thank you very much that sounds like a very good hint! Much appreciated!!!
