4drmadness wrote: Have fun with your car, and pray you dont die at the same time. being a college student with a g is not a very good idea. More to come in the future.
Confused... these 2 comments contradict eachother.4drmadness wrote: Im driving like an asian plus a grandmom/dad next time it rains. dont honk at me locals. i have learnt my lesson the easy way.
no brakes when the car is sliding.once you're good at it you can almost take your hands off the wheel and steer with the throttle.the way to control a skid is to steer into the skid and apply throttle or dial back which ever is necessary. if the car 'goes around,' BOTH FEET IN meaning clutch and brake4drmadness wrote:so nt hitting the brakes at all? jus having control on the steering wheel?
Focusedintntions wrote:I just don't find this story to be that amazing lol...i was thinkin there would like a dukes of hazard jump or something...not a simple lil fishtale....
Show me some Daisy!!
Yeah, no brakes when you're fishtailing. Just let off of the gas because you want to keep the wheels rolling. If you hit the brakes, you could end up worsening the skid, say a 180 or 360. If you hit the brakes, you have to make a conscious effort to apply only very little brake at the opportune moment, but most people out of pure reaction will slam them.4drmadness wrote:so nt hitting the brakes at all? jus having control on the steering wheel?
No, not really. Hydroplaning is caused by going too fast for conditions, simple as that. If you're maintaining a speed that is too fast, then yes you will hydroplane, but maintaining a proper speed will not cause it or increase your chances. Increasing your speed will give you a higher probability of hydroplaning because you are increasing the water pressure on the tire. If the road looks slippery, drive slower and use the proper gear to control the amount of torque. If you downshift in slippery conditions to maintain your speed or slow down and you shift at too high of a speed/RPM, almost guaranteed to lose traction since you're now applying a lot more torque. If you use a lower gear than normal and decide to speed up, you may apply too much torque than what you wanted. If you do use a lower gear, in which some conditions do call for, you have to make sure your tires aren't going to slip. Or if you use a lower gear to drive slower, then sure. Its all about feel and when in a skid, its all about throttle and correct steering.Jacko3 wrote:In rainy conditions, avoid any type or condition of constant speed---it is the fastest way to hydroplane. Vary your speed in the rain for traction purposes! If the road looks slippery drive with lower gears to avoid hydroplanning, and to increase traction. However, watch out for fishtailing. So, throttle input is critical. Just my experience and 2 cents worth.
