ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Dec 28, 2003 7:42 pm
Originally posted by yozsi umm... no timing should be at 15 +/- 2 deg btdc.
timing should be about 20 degrees BTDC. this is what eveyone has been going by in the KAT forums for awhile.>>>>>>yea for the DOHC motor, GUspeed's got the SOHC engine, so yozsi is rite...
also, after doin' that distributor-mod, using a higher octane gas is highly recommended... or your engine go "bye-bye":the SOHC engines didn't come w/ knock sensors
soo, if u can't afford high-octane gas every time, i'd advised against this.
on another note: "I believe the AIV recirulates exhaust gases to lessen the levels of CO2 or sumthin. It's like the catalytic converter in the sense that it reduces harmful emissisons, but hampers performance of a car." <MR2NER>
misinformation, except for the last part<where's that troll that always get's his panties in a bunch when he see's stuff like this??? hehe, j/k>
it basically adds air into the cat converter to "help" it to complete the byproducts of combustion>water + carbon dioxide -yadda yadda yadda. MR2NER is thinkin' maybe the EGR valve "recirulates exhaust gases"
just a dude who read some old threads awhile back...
180fan, if the reeds fail, couldn't u just keep the AIV hose disconnected from the airbox<so water & exhaust gasses won't be "vomited" back into the intake & screw up the MAF,throttlebody valve, etc> & add a breather filter on it? that way, it's still getting air into the cat <not as much> but better than plugging the line... I just did this d/t the high mileage of my car & want to prevent this problem.
