bullittandy wrote:Pics soon...
I have to change my wiring setup as I took the input off the rear package subs into a lineoutput converter and then to RCA's into the Kenwood Sub.
However, there too much juice going into the line output converter (amplified from Bose amp) and even with adjustable settingson the line output converter it distorts on the Kenwood.
I'm going to pick up the preamplified signal tomorrow after looking at the FSM, I was lazy and didn't want to look for it today and instead came staright off the speaker.
{Pics and sound report soon.
Do you think that the speaker level inputs would work? I mean, I know they are supposed to take the high input of speakers but do you think that the sub can cut down the amplified signal from the stock speakers enough?Qproject wrote:doesn't the kenwood sub have a speaker level input ?
use the speaker level inputs, that what it's used for.
and if I were you, try to leave the stock 6.5" functional by splicing the signal. This way you have both the oem subs and the kenwood subs rocking.
I have left the stock package self speakers intact for just that reason.
mcrews wrote:I had purchased a similar subsystem about 6 months ago.It also fit in the armrest solt perfectly.It also had the adjustment knobs on a remote that I ran up into the front armrest.I had also purchased a slicer of some kind and ran it off the rear woofer.unfortunately, it just didnot produce the desired results.I am sorry I dont have any more exact info.I recently moved and have not unpacked the misc garage stuff!!!!
mark.
IT WAS NOT THE KENWOOD. BUT it was a similar enclosed active/passive system with a remote that had 2 little knobs.Qproject wrote:please be more clear, WAS IT THE SAME SYSTEM OR A SIMILAR SYSTEM ?
the kenwood is a dual 6" system , one being a passive radiator set up, so there's a good chance it will out boom whatever u had.
mcrews wrote:IT WAS NOT THE KENWOOD. BUT it was a similar enclosed active/passive system with a remote that had 2 little knobs.
My 'quess' is that the 2 ohm q45 speaker system is not compatible with these off the shelf "bass systems"
but hey, what do I know ......I don't seem to use the word SIMILAR very well.
gezzzzz
mcrews
