am i spinning to much?
da40
Car: 1995 SE 240sx
i have all the obvious upgrades on my s14 i have the red top and just got my boost controller i went up to 12psi and kinda feels the same as 7psi,someone told me i could possibly still be spinning on one wheel more then the other thats why it feels the same .i dont have a lsd should i get one before i turn up the boost or upgrade turbo?
Dori Dori
Car: Cars of course
YES! Pegleg launches not only suck for acceleration but look pretty gay too!
da40
Car: 1995 SE 240sx
thanks for the quick reponse ,so you think i should get the lsd before a turbo upgrade or higher boost?
Tartan
Car: 89 240sx
How's your clutch? My friend with a S14 w/ open diff spun but it still felt faster at 14 psi than at 7psi.
da40
Car: 1995 SE 240sx
its a brand new clutch
da40
Car: 1995 SE 240sx
it was installed when the motor was installed
Fenvy
Car: 2005 350Z Base 6MT
what's power if you can't put it down to the tires?
lsd is more important, if you have money get a cluth type lsd such as kaaz or nismo
good luck
da40
Car: 1995 SE 240sx
thanks for the info..gonna go ahead and get the lsd
Dori Dori
Car: Cars of course
Don't worry about the clutch type unless you drift. A VLSD will be worlds better!
da40
Car: 1995 SE 240sx
thanks again ..the more options i have the better
nismofly
Car: 89 Nissan 240SX Hatch
you might also try some better tires to go along with your tires
da40
Car: 1995 SE 240sx
cool.. that'll work
nismofly
D'OH
tires with your lsd rather...no i havent been drinking
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Id rather save up for a clutch type compared to buying a VLSD. A clutch type locks way faster than a VLSD does.
da40
Car: 1995 SE 240sx
what kind of power are u putting out to the wheel withe your setup?
