AZ89two4Tsx wrote:Alright, I decided to go for a pretty long drive today since I just finished up a little maintenance. I'd say I was about 30mins in when things started to heat up. Mind you I live in Phoenix and it was about 105 out today, and sunny.
Anyways, my car peaked at 230 before I parked it and let it sit for a few mins. The A/C had been off the whole time I'm driving it. My HKS fan controller was warning me and I double checked my Power FC Commander to see if I was running that hot.
Mods:
Redtop SR
S15 Turbo @ 1ish bar
Power FC
Dual Flex-A-Lite fans with HKS fan controller
Koyo Radiator
Vented Hood
On a not so hot day, the car constantly runs around 200 all the time. The fan controller is set to kick in a 200 degrees and does a good job. I'm pondering adding an oil cooler or maybe a bigger pan. It's just so effing hot here and my car is so low that I feel like it just absorbs the heat.....
Ideas? Some cheaper options would be a cooling panel and even some water squirters like Razi on here did..
Umm... 105 is hot as hell, I would blow my brains out living in those conditions. But still, once it hits 205F that's just about as hot as you want it to get while driving. Normal operating temps is at around 175 F to 200 MAX.
You peaked to 230. . . That's pretty severe. Look into putting your clutch fan/shroud back on. That is the most efficient way to cool your SR, screw flex-a-lite's. If you don't want to do that, then get an oil cooler.
Also, try setting the fan controller to 190 F.
