Am I okay with just Clucth Fan?
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
I bought a mishimoto radiator for my ka24de and instead of wiring up an e-fan, would i be okay with just the clutch fan without the fan shroud (it snapped in half). I also don't have the A/C fan either bc i removed the a/c.
so would just the clucth fan be okay to keep the engine cool with the mishimoto radiator?
BigMACKenzie
Car: 1993 Nissan 240SX convertible
replace your shroud and you should be otay
r3v_v3ng3
Car: 91 fastback ka-t
the fan shroud is a must. thats how it directs the flow
grecco28
Car: 1992 240sx
i recomend you get a shroud but the only way you can check it is running whit out it and then you know..
Beez_S13
Car: 1989 Nissan 240sx Coupe
yep, you at least need to get a fan shroud. but i would go ahead and get an e-fan.
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
wired up an e-fan...its fine, thanks anyways
