Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Jul 08, 2008 3:01 am
No it is the opposite. Worn, lose, or sloppy FRONT end link bushings disconnect the front bar FURTHER DELAYING the action, Decreasing the build up of understeer frpm neutral effect of proper springs.
Now the same worn bushings on the rear delay the partial reduction in understeer [created by front bar] towards a more neutral steering.
On a Q the endlinks are attached to the middle of lower arms so the bars move only 1/4 of the body amount. A 1" body roll applies a 1/4" to the bushing which must compress before the bar sees the force.
With 4 bushings per side on the rear hopefully easy to see how 1/16" per bushing can dissapate 1" of body roll without the rear bar ever SEEING any force to restrict. Even the next 1" of body roll is not fully trying to bend the bar.
So it is difficult to just add up a bars stiffness and say it is fully functional with any bushings. Now front has only 2 bushings per endlink so the effective ramp up rate is twice as effective [assuming same wear and sloppiness].
Nylon, urethane, bushings have much less give under compression so the bar resistance occure much faster under much less body roll.Using these can feel like you have doubled or tripled the bars stiffness, but small bumps are instantly coupled to suspension adding impact harshness and the potential to bend or break something.
