Am I Missing Somthing?
moso240
Car: Ferrari V12 Powered S13
Im Doing a Turbo Upgrade on my rb20 and have all the parts shown in the pictures below now heres my question is there something I Should Have thats Not there Besides the turbo? ( ups "lost" the Turbo )
Intake Manifold, DuectschWerks 750cc Injectors, 60-1 Garrett, Exhaust Manifold, Tial 44mm gate.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Hot pipe, cold pipe, couplers, t-bolt clamps, new turbo elbow, downpipe, dump pipe (possibly routed back to the downpipe), intake piping to MAF sensor, new boost controller tap in hot pipe, BOV, BOV flange and recirc line/fitting.
Trust me, it is all the little stuff that nickels and dimes you to death.
moso240
all piping and couplers will be sorted out by my installer which is also making custom downpipe fmic pipes and the works.. I am running a MAP Sensory so how would that work out? And is it possible to use original Rb20 BOV vented instead of recirculating it?
Carl H
stock bpv is not a good bov as it leaks under pressure for a quick release.
Sil240
Car: Nissan S13 "The One Cam Wonder"
What ECU are you running?Because you can't run a MAP sensor with the stock ECU unless you have one of those HKS thingies (CAMP or FCon or whatever).
Yeah you can run the stock BOV vented to atmosphere until you get a bigger one.I dont know if the stock one will be able to flow enough to make sure you dont have compressor surge when you lift throttle.
Are you on IFX??
Darius
Recirculate it. It's not tough and will only cost another $50 tops with all the fittings and some sweet silicone hose. The cheap route with heater hose could cost as little as $15.
If you can wait a week, I'll post more pics up of my progress which will include a recirc line back into a silicone 90 coupler.
240z4u
Car: '95 Nissan 240SX
I see no gaskets for anything holmes.
moso240
AEM EMS....IFX?
Sil240
IFX = Import FanatixTristate Area peopleCheck it out
Yeah if you re-circ you supposed to get better throttle/boost response instead of wasting that boost.
moso240
Ok Great
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
Looks like you went with the real deal ebay special, besides the turbo and wastegate.
I would take the manifold to a shop and have the flanges resurfaced just to make sure you don't have any trouble after installation.
Darius
werd. cheap insurance against boost and exhaust leaks. ($75 tops)
minivan_don
you are also trying to use that 44mm vband wg on a 38mm non-vband flange?
Mistaken
Car: 93 240sx Coupe
Anyone have any experience with that intake manifold.... any comments on quality? Worth the money? I am an engineer for a company that has a full machine shop so i was wondering if that manifold was worth the money if i machine the flanges or if I'm better off just spending the time and money to make my own intake manifold. I have access to a solid modeling problem that will flow test parts so I am shure i could come up with a pretty amazing manifold.
moso240
Quality is not bad at all... atleast mine wasnt The Flanges are level all across and seem Like i will see no problem from them at all
HPF Chrisk
Car: 240sx
i am going to wait and see how that intake manifold fits and if it leans any cylinders out on your car before i buy one for mine.
moso240
STOLEN CALL WITH INFO 347 768 9572
Sil240
To tell you the truth I betcha someone saw your pics online and what you have. Then came and found you.Flushing is not that big...
Hopefully you'll find your car.
Post up on IFX all those guys will look out for it.
moso240
THOUSAND DOLLER REWARD TO WHO EVER LEADS ME TO FIND MY CAR
