Am I missing anything?
MidWest240Collector
This is the stuff I'm planning on getting for my RB20 swap. RB20DET Engine and Transmission Koyo Aluminum Radiator Walbro 255lph HP Fuel Pump Attain Solid Shifter PWR Timing Belt Top Hat Performance RB Mount Kit Top Hat Performance Intercooler Nissan RB20 Waterpump Nissan S13 VLSD Nissan Z32 Fuel Filter Nissan KA24 Oil Filter Nissan RB20 Thermostat Blitz DD BOV with Flange Blitz Racing Meter DC Boost Gauge Blitz Racing Meter DC Pressure Gauge Blitz Racing Meter DC Temperature Gauge Blitz Live Unit Blitz FATT Timer DCII XTD 300ZX NT Clutch Kit
Eikon
Car: 71 240z, 93 Supra TT
I would add an adjustable fuel pressure regulator to that list.
Have you thought about checking the exhaust manifold gaskets? The Rb's are pretty likely to snap the studs. You could get yourself a new set along with a new exhaust manifold gasket. Hit up Goofynick for a copper gasket.
The thermostat is the same as a Z32 NA.. their cheap, unless you want the upgrade to the Nismo one that opens at a lower temp.
How about a manual boost controller? I think you can get them really cheap on ebay or make your own.
That's a pretty impresive swap list. Can't wait to see the results!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Tensionor, Idle pully. Make sure the motor is in good shape. Might as well change the headgasket too with a metal one since the motor isn't in the car.
Eikon
Yeah.. and good luck getting a tensioner and idler pulley.. Oh wait.. I have an extra set you could buy from me.
Carl H
make sure to get a nissan oem z32 TWINTURBO thermostat, the na one is TOO HOT.looks like a pretty consice list of things to get while doing this swap, nice to see that some one is doing the swap right the first time off, and not just shoving it into the car.if you can afford to get a new gt-r water and oil pump, superior to the rb20's in every way.
MidWest240Collector
I want to do it right the first time and not have to fix **** all the time (I would have bought a DSM if I wanted to do that). Do the gtr pumps bolt right up?
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
I've been told yes... but never done it myself.
Speaking of not wanting things to break... replace all of the rubber hoses you can find replacements for... you'll thank yourself later.
Yellow4g63
yeah the rubber ones under the intakemanifold. It's a pain in the *** to get too when the motor is in the car. The coolant hoses fyi.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
If you can't find replacements for the rubber coolant hoses for a reasonable price, are there alternatives out there as far as materials and durability go?
