nissanfreak12 wrote:Fabricate the Radiator bracket, really easy, yes you need to fabricate or buy one premade, only $25
Only downpipes that will work with NA pipes are JDM down pipes, bend is different at about where it connects to the DP
Would it work if I got a Megan downpipe/testpipe combo and fitted it to my cat-back system?
And do you know if Z1 has the pre-made? A link if you don't mind?
nissanfreak12 wrote:You will need a NA shaft if you car was an NA before, they mount differently at the rear end NA is 4 bolt TT is 6 bolt
Is this the driveshaft you are talking about? So that means I should stick to the NA sriveshaft? If not, what driveshaft will work? Again, Z1 has it?
nissanfreak12 wrote:You need at lest 370cc fuel injectors
Is this something extremely necessary to get up and going or am I able to finish the swap and then have the fuel injectors changed from 270 > 370 after a few months? And yes the newer style ones.
Or is it easier to do while the engine is dropped?
nissanfreak12 wrote:Going through your list, I think you are missing a few things, just can't think of them at the moment. I would also highly suggest replacing the knock sensor and KS harness while the engine is out. TT's like to detonate a lot more than NA's, better to have one fresh that can read when it is detonating. Have money off to the side, things will come up. If this is a JDM motor, look for the thread about them. At bare min, I would change the timing belt 120k kit, oil pan, oil pump, reseal the engine.
Thanks, knock sensor + harness added to list!
I already have the 120k timing kit lying around at home.
Oil pan and oil pump - added to list!
Full gasket kit - Ah damn, I feared this! Added to list although I'm afraid of how much it'll cost to install all of that! Would you know?
Thanks again! I really appreciate it
