Am i missing a harness?
Rubyz32
Car: 90 n/a z32
No mods as of yet
Behind the location of where my stereo should be, I have a cut harness. I'm wondering if anyone has available a pic of they're stereo plug. I'm pretty sure the genius before me just clipped the stock harness. Im hoping I can just go to the junkyard and find a harness to replace it with. Any light on this subject would be greatly appreciated. For the record, the car originally had the Bose system. It's a 90 n/a
NolimitZ32
I had the same exact thing in myine when I bought it. You don't necesserily need a harness, just look up on the wiring diagrams at which wire is what and you can splice an aftermarket head unit harness directly into the randomness. Since you had the bose system you can find the wires that go to each of the amps, clip them and both sides and run them as speaker wire from the head unit but they are quite thin and if you are looking for potency or loudness above and beyond the average then you will have to run new wires to each of your speakers. Its not too bad just time consuming.
