Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Mon Jul 25, 2005 11:19 pm
We don't even know what product you have man there are probably hundreds of no name lowering springs with adjustable perches...Im sure some fit fine, some fit with some work and some wont fit without a lot of work.You own the product, you own the car....go find out!!!! If you cant afford much then how can you afford to drop $150 on something that you don't know will fit your car?aftermarket springs can and most likely will be a different size then stock, and will have a different perch if a new one is included...Get some pictures, or a name, so we aren't guessing if some spring some guy sold to you that is the same size front and back...
