Am i forgetting anything(turbo questions)
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
I have a 89 sohc and i want to turbo it. IF i can get the money i am planning on getting a t25(quick spool). And what ever maniflold i can find for the sohc. Other than oil lines and custom piping do i need any thing else(i.e. fuel, computer, maf sensor, larger oil pan) I only want 200+ to the wheels. I will be running 5-6psi. It has to be my daily driver to school.
Any input would be helpful
thanks in advance.
Luderacer14
Car: 96 240sx
I have a t28 and I already wanna go bigger. Thats the problem with these cars, your never satisfied. If your gonna go 6-7, than get 370cc and a safc to control them with a wideband. Just don't get a mbc like I did and turn it up all the way without tuning, if u push anything higher, remember to retard your timing. Those turbos are'int efficient, go for a t28, it's better. You should'int need a 300zx maf if your only gonna push low 200ish. Also go for lower heat range sparkplugs. A 300zx fuel filter is cheap and remember to also upgrade your fuelpump. I know you'll wanna up the power eventually, so might as well do it right the first time.
jab11185
Car: 1992 Nissan 240sx
and if ur gonna get 370s you'll need some top feed ones not normal sr 370s....check the injector spreadsheet to find out what you need
