Am a looking at a fuel volume issue?
coolen
Car: 95 hardbody v6
The other day coming home, my truck lost all power to the point that I had to pull over and nurse it up a hill. I drove acouple more miles, stopped for gas, then continued home-and it seemed to work fine.Til the next day, the problem has come back and has not left. I've changed the maf, o2, tps, distributor, and ran all diagnostic modes. The modes came out at a 55, no mal.I put my fuel pressure tester on yesterday, and at idle it was barely 31psi, and with the vaccum line disconnected, it was just pushing 40psi.
I also took the fuel line off at the rain and let the gas pour into a container, and it seemed to work to get the fuel to come out. I tried just cycling the key, and starting it. Should the fuel not just pour out of the line when the pump is energized? Because like I said, it worked to even push out not even a quarter of a quart.
Thanks
RT22
Car: 1991 nissan hardbody
Fuel pressure regulator may be bad
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Fuel pump issue or a plugged sock it sounds like.
coolen
Car: 95 hardbody v6
I'm thinking fuel pump myself. Does anyone know what our pumps should flow into a container with the fuel line disconnected in say a 30 sec time frame?
