dennisplus wrote:Ok. I'm asking for advice on a little drifting. I drive a 1992 240sx Coupe on Tein coil overs, rear camber kit, toe control, and stock wheels. Ok here's the scenario: I'm going on a straight away towards a left hand turn(90 degree). I'm in about 3rd gear when I shift down to 2nd, brake, go right then left, pull the e-brake as I turn left, pop the clutch and gas it. My entry is beautiful! Totally sideways and at a good speed but right before I exit I spin out. All 180 degrees around! WTF!! Well I was told it might be beacause I floor the gas but I've done it with more gas controll but it still does it. I don't know if I need to adjust my steering due to the fact that my car goes left way easier than right. Please help! I was doing these turns way better when I first tried them but now spin out on every turn! Any opinions?
damn dude youre doing like 5 things at once just to initiate, thats your first problem. pick 1 method of initiation for that specific track/corner and use it.
you are probably using too much throttle, or too much too quickly. if you gas it while the rear end is swinging out you WILL spin.
and i disagree with "more" steering input to a point. in drifting you will steer with the throttle. i know, it doesnt make sense, but for the most part your arms and hands should only make small corrections once sideways to maintain the slide and redirect it to where it needs to do.
i TRY to never make more than a 1/4 turn on the steering wheel once i set my angle after initiation. you drive with your feet. every "newer" person ive ever tried to give advice to (after a ridealong) uses too much hand input.
