SketchyRollin564 »
https://forums.nicoclub.com/sketchyrollin564-u60600.html
Tue Nov 01, 2011 9:32 am
Solid will be a lot stiffer and have no flex, better for drifting and depending on preferance, any track racing
polyurethane is still a LOT stiffer than regular (and worn out 20 year old) rubber, and unlike rubber, it wont deteriorate after time. However compared to solid aluminum, it will still absorb a little bit. It also wont transfer as much noise from the diff to the car that you will hear. Aluminum can usually be had for cheaper. I personally have polyurethane subframe collars (not bushings) in my car, they seem to do their job well. For daily cruising, polyurethane would be better
