aluminum vs steel driveshaft
Abdo
Car: S13 RB25DET
I apologize for the thread-jack.Thanks for your advice Darius, if anything goes wrong with my current u-joint I'll be sure to consider the GM 585.
oneslow240se
Car: 91 240se
Does anyone have measurements for rb25 in s13 chasis using Tophat mounts? I don't have the motor in the car yet so i can't take measurements.. I ask shaftmaster about it and the response i got was it should be the same or close to using Mckinneys mounts... i could not get measurements for neither. Just want to knoe for sure before i put in an order.
Abdo
Car: S13 RB25DET
oneslow240se wrote:Does anyone have measurements for rb25 in s13 chasis using Tophat mounts? I don't have the motor in the car yet so i can't take measurements.. I ask shaftmaster about it and the response i got was it should be the same or close to using Mckinneys mounts... i could not get measurements for neither. Just want to knoe for sure before i put in an order.
Every setup is different, and no two motors sit exactly the same. Given that information you should figure to wait until your motor and transmission are in to order your drive shaft, in other words make measurements yourself, on your own car). Mine was 43" with Tophat mounts, but that doesn't necessarily mean that your drive shaft will be 43".
oneslow240se
Car: 91 240se
i understand what your saying. But if your using the same motor and mounts in the same chasis i would think that length wise should also be the same. When ordering mounts+shaft combo they didn't specify shaft length. So i was under the impression that there is a standard length when using specific mount kit such as Tophat or Mckinney's. other wise they wouldn't be offering a combo option?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Although true, but using mount kits that are properly made...
StricNyne
i agree with cool 100% u had to think about wut he said, and the diagram is icing on the cake
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Once I have the extra money, I will get an aluminum shaft from shaftmasters..
Worse comes to worse, I will take a piece of aluminum sheet metal that may weigh 2 pounds and cover up where the shaft goes and weld it to the body...
Josh
DriftingisLame
Car: '91 240sx coupe, rb20det
I know for a fact that newer chevy pickups use an incredibly light aluminum driveshaft. Why would they put that on an offroad vehicle if it would get damaged driving on the road? I think aluminums are kosh.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Edit: Already taken care of.
Also, price is $349.99 SHIPPED.
Modified by l0nestar at 10:14 PM 11/4/2007
HOMEMADE240SXTURBO
Car: 1989 NISSAN 240SX KA24E
StricNyne wrote:ohh and shaftmasters is 300 SHIPPED for ALUMINUM
tempting...
oneslow240se
Car: 91 240se
i ordered one from shaftmaster. If you do ask for a guy name david, customer service was great well see how alum shaft is once i recieve it.
oneslow240se
Car: 91 240se
just recieved mine.. overall shaft looks great just like the picture in their site .. its 3 inch in diameter just as describe and weighs about 14lbs.. shaft is hollow and not solid hence it being so light ... i have pics but forgot how to post
StricNyne
this is funny, this will make or break shaftmasters for the RB guys lol i mean if its awesome like its seeming sofar it could mean like a minumum of 10 driveshafts
uber95
Car: S14
There aren't many things that can go wrong with a D/S. It's either round and balanced, or it's not. The yoke is either welded correctly or it's not. U joints are a servicable item so that's a non issue. Aluminum is the way to go IMHO, my patrol car has one and the car is maintained very well; but it gets rode hard alot and I've never had a failure. That's running through on average 2 tanks of gas a shift, so like 325-400 miles per 12 hour shift, 160+ hours per month. I think the aluminum shaft will last no problem.
l0nestar
2004 Toyota Altezza
I just received my DS from them. I will try and dry-fit it tonight! Everything looks good. David is awesome!
One side note, the price went up to $349.99 shipped - their cost on aluminum went up :-\ But he told me this info before he processed my payment, and was up front with me about it.
I'll let you guys know how it turns out after I get it properly installed and some MT-90
l0nestar
2004 Toyota Altezza
Well, I just went to install my new DS.. and the yolk is wrong (diameter is too small) I called David and he was very helpful. I read him the part# on my yolk and he confirmed that it was for a standard S13 (KA or SR?) - Not RB!
But he just shipped out the correct yolk to me (should be here by Friday). I will see how this goes. I could have been pretty peeved, but he was very polite and apologized for the error on their part and tried to make good of it. I'm still calm, so it is good
The quality of the welds is very good also.
blurrbosi
Car: 240's
I went aluminum. No denting here in FLA.
Shahee1
Car: 1993 240sx w RB20DET
I have aluminum and I don't have any dents either ...
l0nestar
2004 Toyota Altezza
I received my replacement DS from ShaftMasters. It fit perfect. No complaints. Saved quite a few lbs. as well.
Satisfied Customer.
StricNyne
any pics ? i am gunna measure and order one once my mounts come in i will psot an update
