Aluminum vs chromoly flywheel
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
what is the better flywheel to use on a rwd sr20det.a aluminum type like the fidanza,or a chromoly steel type like the toda or jun.is the chromoly alot stonger.and is the aluminum alot lighter,stuff like that.thanks,brian
180crafter
Car: Nissan 240sx
i Belive the weight savings are the same, but there are 2 very impertant differences. On the Aluminum flywheels, the friction surface can usually be replaced while the chromoly are usually one peice units. I also know that the Chromoly usually cost an 5hitload more than Aluminum. I have heard of high boost cars shattering aluminum ones, but that Is one thing that your average consumer would not car about.
In My honest opinion, I will always suggest the aluminum, but buy myself the item.Chromoly.
240Kuminachu
Chromoly is stronger, Ive heard of of aluminum warping and like he said, shattering..
Ive got a TODA chromoly and its awsome.
If your not looking for alot of power aluminum will be fine.
Cyberkreig
Car: 1993 Nissan 240SX SR
i've got jun ultralight chromoly. :thumbup
I know that doesnt answer your question but look at it this way, If companies like JUN & TODA use chromoly its probably for a reason.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
The stock flywheel...that's where it's at :thumbup
If you want to lighten the drivetrain, I say carbon fiber driveshaft would be a better investment.
Cyberkreig
pff, for the cost of one custom CF driveshaft you can have an enjuku aluminum shaft and a light flywheel of your choice. While its probably overall the same weight loss, IMHO there are benifits. 90% of SR20 owners have no chance of breaking an ALDS, where as any sort of impact on the side/shaft of the CFDS could be disaster.
cnichols
99 Infiniti Q45
93 Ford Fastiva
http://www.ws6.com/mod-10.htm
I still prefer CF if I'm going to do it. When will the driveshaft be impacted?
Cyberkreig
its not likely it will ever be impacted, BUT it could happen if you drive over something largely un even, a curb incident, road junk, or even from sliding sideways.
I dont aruge the benifits of CF over AL, simply that I, and I would guess most people, cant afford a $1200 DS. Not to mention if you have to buy it twice.
cnichols
99 Infiniti Q45
93 Ford Fastiva
Knock off about $400. :D
FTRS14.5
Chromoly is better!!!!
cnichols
99 Infiniti Q45
93 Ford Fastiva
You forgot the part where you explain why. ;)
Cyberkreig
really? 800 isnt so bad. last i looked into one i remember the number 1200..
i'm not enough of a baller for either of those numbers tho =P
cnichols
99 Infiniti Q45
93 Ford Fastiva
Me neither...haha
FTRS14.5
Why do I need an explanation? Just say the word "Chromoly" Doesn't it just sound better?? " Hey everbody, I got a "Chromoly flywheel" Hehehe (Just being sarcastic :pface )
