compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Thu Feb 16, 2012 10:44 am
Yes it would but unless your making some serious power, I doubt a few degrees would matter. As far as the axle angle it would help that on a lowered car but mainly what I was referring to was, when the suspension travels, the camber and toe change more progressively the further away from the axis point you go. That's why they make aftermarket ball joints that are longer, which puts the lca further away from the spindle to help with this. If you are planning on making some serious power, id go with stock sized bushings that way you don't start breaking u-joints.
