aluminum radiator
jiggersplat
Car: 2008 Infiniti M45x
1995 Toyota Supra TT 6-spd
anyone make an aftermarket performance/aluminum radiator for us? apparently i need a new one.
yayo1189
Car: 2009 Infiniti M35X
I wouldn't recommend all aluminum radiator. I just replaced mine with a Koyo radiator, I used aluminum hoses and the anti freeze dried out faster being that the hose was metal. Also I went on carid.com and thought mishimoto had an aluminum radiator for the m35x, ordered it and found out one it wouldn't work because it didn't have two lines for the transmission fluid to run into. The factory radiator needs two lines to run the transmission fluid to, I learned it while replacing my radiator.
fat3oy
Car: 07 M35X, 06 350z, 06 RSX, 99 Dajiban
Nobody does. I made one for my car - using a mishimoto g35 radiator as a base - also needed an external transmission cooler. Car runs great, and much cooler with the dual core - not to mention looks nicer. But as far as a buy and install - s*** out of luck
