Aluminum Radiator
Edub1
Car: 89 240sx KA-T
Can't seem to find a good, reasonably priced aluminum radiator for the SOHC.
Some adds seem to suggest that the E & DE are interchangable while others suggest otherwise.
What to do?
boznuttz
Car: MS13
how much were you willign to spend, i saw some nice koyo aluminum rads for around 400. why not look into the copper rads too? the metal just dents and bends easier i believe
WDRacing
Copper is more expensive, and heavier then aluminum. Its is however better at thermal conductivity, meaning it will act as a better heat sink. But I went with Koyo myself. I wish I could say for sure if the rads are interchangeable between E and DE. Maybe someone will chime in. Have you asked this question in the KA forum? I know they're weak being NA and all, but some of them dudes are pretty smart.
WD
Burnsey
Car: '92 Infiniti Q45 ... 89' Nissan 240sx
boznuttz wrote:how much were you willign to spend, i saw some nice koyo aluminum rads for around 400. why not look into the copper rads too? the metal just dents and bends easier i believe
our sponsors have them for like $300-320ish I do believe ... dbl row koyos.
boznuttz
Car: MS13
only issue i have heard of is the drain plug leak issues. easily fixable.
24DSXY1
Car: 1991 NISSAN 240SX
Drain plug problems? I have an aluminum koyo on my s13, but it doesn't leak. Are some koyo's defective?
rotorimp
Car: 02 Xterra, 60 IH Metro
Most of the KOYO's leak around the filler neck--anyone have one that does not leak at the radiator cap.
Burnsey
24DSXY1 wrote:Drain plug problems? I have an aluminum koyo on my s13, but it doesn't leak. Are some koyo's defective?
they might leak, or when you go to take the drain plug out ... it strips and then blah! ... your left finding a way to get that out <--- happened to me the other day ... KAtwo4o did a write up on the drain plug fix title was "I hate you Koyo Parts Committee" or somethin like that .... I have yet to find someone who carries the M10x1.00 bolt tho
WDRacing
Easiest fix would be to Oxy a new bung on there I'd say...but we all can't weld.
24DSXY1
I've never drained my coolant yet but what your saying is that when I do open it for the first time, the plug will break and I'll need to find something else to plug it up?
WDRacing
Or pull off the hose and drain it that way...
24DSXY1
That's what I was thinking of doing since I'm now afraid to ever open the drain plug, ever. Thanks!
hek1620
Car: '89 240sx
the single slammer has both inlet/outlet on the pass. side. the de has one on either side. and what sponsor is letting them fly for 300ish?? i've been looking for awhile.
hannibal
Car: Red Line to Glenmont
Intense was $289 like 6 months ago. Eww, its $347 now!!! But check this thread. He seems to be doing deals for NICO members...zer...age=3
WDRacing
Good lookin out bro...
Edub1
Car: 89 240sx KA-T
You sure? All DEs?
nismofly
Car: 89 Nissan 240SX Hatch
price of aluminum's on the rise so they wont be going down anytime soon if youre thinking about waiting
Edub1
Car: 89 240sx KA-T
Nobody knows where to get a radiator for the sohc?
Are you guys all running stock rads with your turbos?
I'm thinking of buying one for a DE and having the inlet relocated.
lrb_2000
Car: '91 Nissan KA-T hatch
plenty of people are running stock cooling with their turbos, why upgrage if it's not getting hot?
wild_maxx
Car: 90 TT pearl yellow z32
I am using my stock 18yr SOHC radiator on my turbo setup with NO overheating issues at all. I use a tuarus SHO hi and low speed fan with an adjustable thermostat controller to kick it on. It has never kicked on HI.... the LOW speed workes just fine.
During this past summer it was pretty damn hot, around 100*+ days were normal and I boosted the crap outta my car with no problems. Fluid was standard antifreeze 50/50 mix with water.
hek1620
Car: '89 240sx
i guess 100* in miami, is hotter than anywhere else. i run altima fans on hi and i get overheating issues on the highway. especially on hot days with the a/c on. but sitting in traffic w/ ac no problems.
wild_maxx
You get overheating issues while driving on the highway? Thats pretty unusual. I don't have a/c in my car so that may be another reason why I don't have overheating problems. I do have a FMIC but that doesn't cause any problems with the radiator.
babowc
Car: 240sx
im getting a deal on mine.115 shipped for dbl row s13 koyo
90 bux + 25 shipping.its a used with bent fins, doesnt affect performance too much id say./
boznuttz
Car: MS13
thats an awesome find, seriously! my brother and i have blown several of the ka24de rads on both my ka and his sr setups. it is ALWAYS overheating the plastic return peice and shattering. we can normally pick up rads from the junkyard for 30 to 40 bucks, but its just gettign REALLY annoying. ill upgrade to electric fans soon anyway and see if i can save a few bucks.
Edub1
Car: 89 240sx KA-T
Why are you overheating?
Clutch fans are the best there are. You have the shroud in place?
babowc
Car: 240sx
never hurts to upgrade clutch fans ARE the best..really it is, but im still changing to electric fans...
boznuttz
Car: MS13
Suicide.Veteran
Car: 93 Nissan 240sx
boznuttz wrote:thats an awesome find, seriously! my brother and i have blown several of the ka24de rads on both my ka and his sr setups. it is ALWAYS overheating the plastic return peice and shattering. we can normally pick up rads from the junkyard for 30 to 40 bucks, but its just gettign REALLY annoying. ill upgrade to electric fans soon anyway and see if i can save a few bucks.
yeah, my top port broke on me and sprayed me with hot antifreeze. I go t a second degree burn on my arm.....FVCKING PLASTIC
S13FX
Car: '69 l20b Dimeski :)
I bought one on ebay heh, it says it's a Koyo when I got it I think it was a knock off. But Iv been using it forever and a day now and still no problems.
