Aluminum or Iron?
S13 King
Car: cars, performance, girls
I was just curious to know what is the better caliper for the Z32brake swap the Aluminum or the Iron calipers?
And also I'm looking for the Brembo OEM type rotors for the 300zx TT for the fronts and the Brembo OEM type rotors for the rear of the 240sx.
Wakkolio
Iron is better, doesn't warp like aluminium.
S13 King
so people really just get the 30mm aluminum for what? Weight i'd assume?
And i don' tthink there really is a need for the drilled or slotted rotors, the Brembo OEM type rotors should hold up very nicely.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i don't think the 30mm's were offered in iron.
S13 King
i'll check in thatbut if they were offered in iron would it be better to have those or to have the aluminum ones?
Supafly
30mm were offered in iron and aluminum. alum. is better for weight savings but the iron ones will fare better under hard braking because the iron can absorb more heat than the aluminum.
S13 King
so iron then,lol
crzycav86
Car: 93 Nissan 240SX KAT
The aluminum came in 26 and 30mm for a short time. The 30mm iron came out in the later models.
I personally have a set of 30mm iron that I wouldn't mind trading for 26 or 30 mm aluminum, solely for the unsprung weight savings.
S13 King
is it really that bad?
What is the weight diff?
EnzoRWD
Car: 1997 Volvo 850 T5
weight diff in quasisubstantial. i dunno, running long straights in a roadrace, u might see some benefit in big iron calipers. i got 30mm iron for such reasons.-enzo
S13 King
yea well i just plan on using the car when ever finished,lolto be daily driven, road and track every now and then, and spirited driving,lol
