Aluminum Driveshafts are perfectly fine for daily driving. They are great, you could possibly even notice an increase in fuel mileage. With a one piece solid shaft you may hear a little bit of noise when shifting or just a tiny bit of diff noise. Nothing bad at all just because you are eliminating the center support bearing and rubber insulator that causes power loss and slop. Just go for it, it is not a bad upgrade at all.
Make sure you also change the rear seal on the transmission when you replace the shaft since it is right there.
The Driveshaft Shop makes a really good driveshaft. Shaftmasters does too, the one on 240sxmotoring.com looks like the Shaftmasters units. I have dealt with both and they are both great quality. The Driveshaft Shop one does have re-greasable U-Joints which is a definite plus, i also like the way theirs is balanced. Both are really good though!
