RBbugBITme wrote:Granted I misread your post, your drag racing/daily driver comments make no sense. The highest stresses on a rod occur at TDC when there is no gas pressure acting on the piston. This occurs every cycle in a 4-stroke engine and the stress increases with RPM. So unless you don't shift until 7500+ RPMs between every stop light I think your point is baseless. In fact I'm not sure you even read your own source.... from the President of the company, "With the material we've got and they way we manufacture the connecting rods, they'll live a couple hundred thousand miles on the street because a street application is, for the most part, low load."
ONCE AGAIN... You need to read carefully. If you notice, the first statement was talking about what the general misconception of the aluminum stretch that began in the early 70's due to lesser mfg processes that are in use now.
The second part of my post states that the reason alloy rods are not as common in street use NOW is due to the fatigue life of aluminum rods and the need to have them checked more often than Steel or Ti rods.
