Altmia KA
jramospma
Car: 240SX Coupe
Hello everybody i´m from Panama and i have a question. can i swap an KA24 DOHC head from Altima to my 240SX KA24E ?
what part´s can i need from altima´s engine? head, intake, wirless, ecu
Can i use the same SOHC ecu and harness ?
Thank´s
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Altima cylinder heads have the upper water passage on the exhaust side of the head. The water neck on the 240sx share a bolt with the main portion of the manifold, not easy to cut it away and make it work. Altima intake manifolds are flipped compared to 240sx, the throttle body is on the back side of the engine.
You can do it, but i would suggest fabbing a custom intake manifold. I use altima heads on my hybrid engines. The absence of the water neck on intake manifold side makes that much easier.
