InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Tue Apr 11, 2006 6:42 pm
Well, it may not be the lockup solenoid itself that's malfunctioning, but rather something else that's telling it to lock up when it shouldn't.
Basically, what happens is as you're driving down the road at a constant throttle position when the car is warm, the revs will suddenly start to jump up, then fall back, then jump up and just go wild in general. Sometimes it just does it a little bit and it goes away, other times it gets to the point where the car bucks constantly, the revs go all over the place, and the car dies if you try to stop. Then dies when you try to start it, unless you stomp on the gas after doing so. It will even exhibit this behavior when in neutral or park.
It seems to go away if you push the gas pretty hard. I imagine the WOT switch on the TPS disables the lockup circuit.
