Altima stuck in Fail Safe mode after MAF failure
General discussion area for the U13-chassis Altima
kirkbrennan
Car: 1994 Altima SE
My '94 Altima has been starting hard for the past several weeks, then totally died. A general tour around the engine compartment included unplugging the Mass Airflow Sensor, which allowed the car to start. Replaced it with a used one, to no avail. With MAF unplugged, it starts, idles, won't go over 2500 RPM. Check Engine Light comes on at this point. When I shut it down then restart it, Check Engine Light stays off until 2500 RPM. Research indicates bad MAF wiring or bad ECU. Any ideas??
Return to “1st Generation Altima Sedan (1993-1997)”
