MilesY »
https://forums.nicoclub.com/milesy-u289937.html
Wed May 15, 2019 9:52 pm
I’ve had this issue for a few years now. It is almost certainly a fuel problem. You have 2 options if you don’t want to fix it.
1. Turn the key to the on position for a few seconds before trying to start the engine. This gives the fuel pump a few seconds to pressurize the line. (This is my preferred method).
2. If you’ve already started trying to just turn over then engine, and it is just sputtering, turn it off for a few seconds. Then while you are trying to start the car, floor the gas until you hear/feel the engine engage. (This is an old school method used on non fuel-injected cars, but for some reason it also works here).
3. Pay someone more than your car is worth and your right leg to fix the fuel line.
