Altima SE-R wheels on a S14 issue
mdgeist
Car: 96 s14 w/ sr20det red top
I have a set of 2007 Altima SE-R wheels. I've test fitted them, but it looks like they will rub against my shocks(stock); and I do not know if they will clear on my S14.
Rex
Car: None
Pretty sure the FWD offsets are going to have these sitting too far in on any RWD car.
To know for sure and by how much, we'll need to know the size & offset of the wheels (stamped on back) and the tires you plan to run.
Soravia
Car: 2003 Audi A4 1.8T
get spacers and longer wheel studs.
mdgeist
The wheels are 18x8 all around.I want to mount 225/40/18 or 225/35/18 on them.Any suggestions?
hannibal
Car: Red Line to Glenmont
Gotta know the offset. That tells you where the wheel sits relative to the hub. I'm guessing those wheels are at least +40...
mdgeist
The wheels are 18x8 with the offset of 45. Mounting 225/35/18 or 225/40/18 on it.What kind of spacers will work? Do I need extended studs also?
Modified by mdgeist at 1:42 PM 9/20/2007
Rex
Car: None
mdgeist wrote:The wheels are 18x8 with the offset of 45. Mounting 225/35/18 or 225/40/18 on it.What kind of spacers will work? Do I need extended studs also?
I'd say you'd need 15mm at the least.
Check a few of the fitment threads.
And yes you pretty much need extended studs for anything over a 5-7mm spacer. Unless the spacers are "bolt-on", which is probably what you want in the 20mm and up range.
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
Yes, the wheels are 18x8 with a +45 offset. I would have to agree with Rex and say that 15mm would look good. Anything less and you'll look sunken in.
