Altima SE-R Oil Gauge
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
Esteban Mayer
Car: 2005 Nissan Altima SE-R
Is it normal for my oil gauge in the center dash that only the SE-R has to be in 0 when in neutral like in a redlight stop?? i thought it should always be in between the last to markers??
rb26dett1989
Car: Nissan Altima SE R
hey there!
ok, so at idle, your se-r should be @ 5-10, @ 45mph, it should be @ 30psi, and at freeway speeds, it should be at 35psi.
check your oil. I usually fill 5.5qrts in my se-r
i hope this helps!
Return to “3rd Generation Altima Sedan (2002-2006)”
