Altima rotors for q45 brake upgrade
Neejay
Ive read somewhere that I can just use the 93-97 (but see 93-01 listed) altima rotors with the q45 stuff so I wont have to redrill the q45 rotors.
Is this true? I tried searching the rotor sizes but had no luck. I also read something about the offset of the rotors being different because of FWD.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
No...that's for using the "jDm" S13 front calipers.
Q45 calipers require Q45 rotors...and if you need 4-lug, you'll need them re-drilled.
- Brian
Neejay
:: orion :: wrote:No...that's for using the "jDm" S13 front calipers.
- Brian
Yeah, ok. Thats what I was thinking...I know you can use them in the "jDm" setup, but I thought it was weird to see someone say you can use them with the q45 setup.
You got any idea whats a decent price for rotor re-drilling?
Modified by Neejay at 5:17 PM 4/11/2005
