Altima pulls to right
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
supermario1700
Car: 2005 Altima 2.5 S
2005 altima after changing front end suspension ( arm controllers, bolt joints and shacks) started pulling to the right. Put new tires on it get alignment done at 2 different shops , rotated tires and it is still pulling to the right side. On local roads is not so bad but with higher speed is is getting worse. I noticed with lower speeds
when going over bumps or road uneven surface is pulls hard to the right. I thought it could be due to faulty parts which has been installed but we replaced it and car behaves the same.Tire/alignment shops have no clue what could cause the problem/ my mechanic is out of ideas / nissan dealership has no remedy.
Any ideas on your side ?
sergofast
I had the same issue but was pulling to the left. The last step I am taking is replacing both front struts.
DrewH
Car: 2006 Altima SE R
2012 G37X
Figured I'd chime in as well to say that mine inexplicably pulls to the left.
Return to “3rd Generation Altima Sedan (2002-2006)”
