liquid_cool »
https://forums.nicoclub.com/liquid-cool-u100587.html
Sat Jun 27, 2009 5:29 am
they may fit...but there are alot of considerations you should look into before doing sumpin like this..
#1.) do you have to clearence the valves?..( if it does..and you dont clearence them..you will smack them on a piston and blamo..your screwed.)#2.) do you have good gas in your area for the higher compretion set up?..and can you afford the gas for this set up?#3.) do you plan on a turbo set up later on?...if so..dont go this route.#4.) can you handle the anoying vibrations that your car will have with a high stroke high comretion build?..
food for thought bro.
