ROFL. You act like people here OWE you an answer. We/they don't owe you anything, besides, this topic has been covered on here DOZENS of times. Search buddy. If you're going to be an a** like you are right now, I hope nobody gives you an answer, d!ck.Hoffman5982 wrote:.Ive asked 3 times and have gotten nothing, so stop di**ing around.
I set it as low as it could go and it wouldn't turn on after I warmed my engine up.AZhitman wrote:That knob is the temp adjustment point.
So it functions as a thermostat. Set it below the "on" temp, and the fans will come on when the temp exceeds that point.
p.s. Don't be a butthole.
If you're not gonna use a relay, I'm not helping you.Hoffman5982 wrote: Ive had better luck without a relay than I hava with one, so Im not using one. if you need pictures then Ill get some
I didnt have an attitude when I asked before. I dont need anyones opinionsWc240 wrote:why dont you try compare your wiring to the many writeups wiring.AZ89two4Tsx is wright. no one here owes you anything. if you've asked three times with the attitude you have on this post, i cant blame peaple for f'n with ya. there are many wiring pictures on nico covering this. also, for something so simple you shouldnt need one.picture of your wiring would help and next time do ask tech questions on a f'kn general chat page
Ok well the biggest problem Ive been having is I dont know which prongs on the controller need to go to the relay. I wasnt getting any answers so I just took it out.AZhitman wrote:
It's dumb. Your electrical system is not designed to handle that kind of instant load, repeatedly.
See my post re: your thermostat above.
I KNOW. scroll through and youll see where I asked a question. The only thing I need answered is which prong on the controller goes to the relay. If someone gives me that I will send you a thank you letterWc240 wrote:dude, 5 threads down the page is a post about fan controller help, with a diagram, mounting and everything.look at that and see why yours isnt workin. look at it and see if your is different
are you talking about the diagram I just posted? I know it shows which goes to the controller, but Im trying to figure out which prong on the controller it goes to. 2 or C.lol thats all Ive been asking this whole timeWc240 wrote:i know, i saw your posts. i wanted you to look at it again. it says in the pic what wire goes where. the answer is there. id load the pic but im super lazy right know.
did it not get peoples attention? my goal was reachedWc240 wrote:starting a thread on NICO that says NICO IS STARTING TO PISS ME OFF is like goin to an irish pub and yelling "F##K all you Mic mutherfu##ers" and thinking youll be able to have a pleasant night
dude are you serious? first off, were past the whole name calling, are you seriously going to be that guy that tries to start things off again? second, if I wanted a honda I would have gotten one.Im not an electrician. Wiring relays and fan controllers is new to me. sorry im not as gifted as youKC240SR wrote:If you can't figure out how to wire up fans then you are obviously retardedand should sell your car and get a honda, you F**KING A**HOLE.
p.s. you suck
thank you. in the first pic it doesnt look like your using a relay. so the blue wire goes to the 30 prong on the relay,and the C prong on the controller would be spliced into that?DRIFTKNIGHT_240 wrote:place it therethe best you can do is to run a wire to the fuse box inside the driver side and connected in the fuel pump fuse. make sure you tie the wire like this so the fans will be at high speed.you have to trim a little bit the fans to make them fit.
it will look like this ... man mines work just fine!!!
ps : dnt run it through thge battery cuz when you turn ur car off the fans are ghoing to still running untill the engine cool of....an d then ur battery is going to die..
Modified by DRIFTKNIGHT_240 at 7:04 PM 6/3/2009
