The fans work in ground circuits of 2
Any Altima 93-01 fan is and will workThey have high speed, and low speed as well, you'll hafta test to see what each is, as I forget.
On my car:Yellow is powerGreen and Black should both be grounded
You WILL NEED a 30amp relay to work these fans...if not, you will melt your wires down. Use 10-12 gaue wire if possible from battery to relay for your source.
I have the trigger for the fans sourced from the Fuel pump relay wire. When I key on, the fuel pump is activated, and so is power to the fan. I have my driver side wired up to run constant (to mimic the main fan) and the other side wired into a fan controller to come on at 165/170.
Driving it for a while now, and having the car never get warm, I've since disconnected the permenant fan, and just rely on the one side and the fan controller to work. So far it works awesome. I plug the other fan back in for HPDE or similar events.
TIP: Use the OEM connectors that yo ushould get with the fans to your advantage. That way you have a nice quick connect if need be
