If you use the stock harness, the fan will only come on when you turn the A/C on. It's easier to wire it yourself. I posted a diagram a while ago, I think it's in a thread titled the definitive altima fans thread. All you have to do is find a switched power source (i.e. one that has power only when the car is on) and wire your relay and everything to that. If you find that thread you will understand everything there is to know about altima fans.
Edit: don't bother searching, that's not the name of the thread. I found it though, here it is. It has pictures and a few diagrams, 2 by me using the through-radiator thermo switch and another by Nissan240sxs12 showing an in-hose switch. Good thread, lots of info.
Edit 2: lol forgot the link. Here it is
zerothread?id=368144
