Altima coupe vs Accord coupe
desertdragon
Car: 2008 Altima coupe 3.5 SE with CVT Winter Frost
I saw this on the other Forum, you might be intereted.http://www.edmunds.com/apps/vd...ber=1
SHIFT_2.5S
Car: 2008 Nissan Altima Coupe S 2.5
There have been several threads about this topic. Thanks for that long, in-depth topic though.
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
Not a favorable review for the coupe. But, did you read the blogs about the sedan Seems all of them love it
Dexion
6.2 seconds 0-60? 14.7 1/4 mile time? Geez Edmunds needs some better drivers.
gotak
Car: 2007 Sentra SE-R
I couldn't stop laughing at the description of the shifter. Maybe someone will do a mod with a leg of lamb.
Dexion
gotak wrote:I couldn't stop laughing at the description of the shifter. Maybe someone will do a mod with a leg of lamb.
That part I do agree with though, the shifter on the sedan feels clunky too, I'm used to it though.
mcheddadi
Car: R8
Dexion wrote: That part I do agree with though, the shifter on the sedan feels clunky too, I'm used to it though.
yeah I agree with them on that part, I think they nailed how an unwell lubricated manual shifter feels!
I did realize this a long time ago though. I had the 04 Maxima and it had the same clunky feeling. They really nailed it with the description lol
"The Altima's driveline also proved to be something of a mess. Clutch uptake was sticky and unpredictable. The transmission shift linkage felt like it was made of cartilage, and quickly moving the long-throw shifter felt as if we were dislocating the leg of some small animal."
hahaha, but since then ,I have found a way to get rid of clunkiness in the shifter, just change the crappy manual transmission fluid for a Redline MTL / MT-90 mixture (60% MTL, 40% MT-90)
I recommend mixing the fluid outside the transmission, and then pouring in the mix. The easiest way to mix it is using a 1 liter metric measuring cup. Basically, you fill the cup with 600 mL (0.6 L) of Redline MTL, and then you fill the remaining 400 mL (0.4 L) with Redline MT-90. Mix thoroughly with a stir stick, and then pump it into the fill hole of the transmission. It will take just under 3 measuring cups (including some lost fluid in the pump that you'll need to get the fluid into the transmission).
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
I had plans on changing the fluid as well. Folks with the Spec-V when I had mine did the same mix with great results.
