I've got a question for you then - is it possible to have the remote start function placed onto a button on the existing Altima Coupe keyfob? or a combination of buttons perhaps? I'm definitely interested in a remote starter, but I'd rather not have to carry two keyfobs around...SpankingClean wrote: If installed CORRECTLY there is no problem. There is NO key left in the vehicle unless the installer doesn't have access to the latest technology. Whomever stated that the key is under the hood is "close" to being correct. Many of the connection (about 7 or so) are run to the fuse box under the hood. The remaining "many" connections are made inside. The factory secutiy is left completely intact and everything works fine. Last week we did an 07 Altima with Remote Starter, Keyless Entry, and trunk release. All work beautiful. This was job sent to us by a neighboring Auto Sound Shop. They didn't have the technology or experience with the vehicle. It is NOT AN EASY installation but can be done NO PROBLEM!!!
Here is a thread from awhile ago, sounds like he got a remote start where he can just click a combination of buttons to start on the regular altima key fob.hangtime23 wrote:
That's really good to know. I had heard what I said from a tv show warning against it (can't remember which), but I may myself want to get one put in and would rather get aftermarket if it can be done right.SpankingClean wrote: If installed CORRECTLY there is no problem. There is NO key left in the vehicle unless the installer doesn't have access to the latest technology. Whomever stated that the key is under the hood is "close" to being correct.
I'm pretty sure it's not aftermarket as it is offered by Lexus itself. It maybe made by another company but most parts are like that like having Bose system or Lo-Jack alarm system. It's an option you can add. Here's the link to the remote start available for the IS250: http://beta.lexus-parts.com/pa...90066SpankingClean wrote:RFX45I have never seen a factory Lexus remote starter. In all Toyota/Lexus vehicles (at least for the last 5 years or so) anytime that the car is running the factory fab goes dead. Lexus had it built into the key and NOW Toyotas have it like that. Most likely the system you are talking about is aftermarket but contains all the functions of the factory fab plus the remote starter option.
