Altima Coupe Headlight Bulb Replacement??
All things Altima Coupe.
s7mk
Car: 2007 Honda Civic Coupe 5-spd
What's the easiest way to change the bulbs on these cars? I own a civic, and for me it's just turning the wheel, pulling the fender liner, and reaching in. I've been doing a lil searching on this forums and nissanhelp, haven't found anything, partly due to search results including TONS of other forums.
Any help guys?
s7mk
BTW, this is for my cousin's coupe, which I put the eibach prokit springs on for him.
DAAN.
remove bumper and headlight to replace
losenone
Car: AC 3.5 CVT K12
You can take the wheel off and pull back the shrowd to replace the light, no need to take off the bumper.
s7mk
Are there a bunch of clips that hold the fender liner on?? How do the clips work?
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
just put a flathead screwdriver between the outer ring and the clip head and prop it out, they're not screwed in, they're just held in by pressure
Modified by Blackmobile at 1:19 PM 11/27/2009
JLAUDIO85
Car: 08 Black Altima Coupe 2.5SL CVT.
mikey??? lol
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Welcome to the club!!!
http://forums.altimas.org/zeromain is the link you should bookmark!
All the info here is in its proper section (for the most part)... Please try and post in the correct area!(this type of discussion is in the "Interior/Exterior" Section.... take a look over there, all the answers are within! In a nice sticky at the top no less!
The search button works too, and we are always here to help you out! (again post in the right section if you can, if you arent sure, dont worry theres no beatings issued!)
downedzephyr
Car: 09 Altima Coupe 3.5se
zerothread/294364it's originally for HID installs, but just follow the steps leading up the the actual installation of the HIDs. It'll show you how to remove the wheel well linings.
Removing your bumper is just too much of a pain ><
blackteam02
Car: Devil in a Blue Dress
losenone wrote:You can take the wheel off and pull back the shrowd to replace the light, no need to take off the bumper.
AMEN! you dont need to remove the damn bumper thats just toooo much work to just replace a bulb!
Take the wheel off and peel the wheel well shroud back alil and , look up!there it is!!!!
