Altima Coupe Fog Light Help
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
Hey I just bought a 2008 Nissan Altima 2.5S Coupe w/ out fog lights and now want to install them. Does anyone have any suggestions as to where to get them, should i get oem or aftermarket, Tips, anything that will help.
Thanks
BlackNWhite
Car: 08 Altima Coupe
The actual install is easy. Remove the plastic bottom covering... and just one screw holds the blank. Remove that and use that same screw for the fog light.
Now, the wiring is the hard part. No 2.5's are pre-wired for fogs so that's the part I can't help you with.
