Alright, so I got the Y-pipe installed yesterday. I had one complaint about that install. Racingline doesn't include any gaskets. That means you have to reuse the stock ones, or come up with your own.
Unfortunately, we ran into a snag partly because of the sealing business. Pictures are worth a 1000 words so I'll just show you.
I felt Racingline should address this issue, as it isn't a simple "bolt-on" anymore if you have to mod the y-pipe to properly install on the car it was made to fit...
Aside from that issue, it was a simple install. I think though, I may be hearing some kind of rattle from the very bolts that were put on the Y-pipe and cat-back joint. Sounds like either one of the nuts came loose minutes after leaving the shop, or the new metal is just clanky right now, but I doubt that is the cause. It's not very loud, but noticeable when idling. There also seams to be some water dripping from the cat-back and y-pipe joint (I had to re use the cat-back's gasket on that part, maybe it's worn after 1 year and 30k miles?), so that may be the symptom of a loose bolt? Hmm, I'll have to get it looked at Monday.
Sound wise, there is more of a mid level loudness to the car, and a reverberation/vibration that is noticeable now around the car under load, just barely, possibly related to the sound. It's not bad, but I would prefer it not be there. The sound is somewhat subtly different, not able to quite put my finger on it but it's a tad louder overall, and is more of a rasp/growl, just a little.
Performance wise, I don't really seem to be able to tell the difference as so many people jump to say "Yeah I notice it dood!" with the 8-10 whp as claimed by Racingline. Then again it's ONLY a 4-5% increase in overall power, so I think that's probably why. No offense to anyone, but I believe there is too much of the placebo effect with many bolt on mods, where people think their car is faster just using their butt dyno, when realistically the difference is so minute that it has to be measured against some baseline to tell the difference, if nothing more than numerically, on paper.
Total: $311 shipped, $40 install.
