Altima Coupe 2008 Windows work!!!!!!!? SET UP!!!? WTF!!!?
All things Altima Coupe.
theboydiddy
whats up guys?does anyone of you guys know how the windows on the altima coupe 08 works?i mean, i heard you can close the window just by putting your key on the door and turning left (i think) i have tried turning left or right, and does not work. I've seen a video on youtube, with the dude opening and closing windows and sun roof with the key. Mine? only open windows, and not sun roof and ONLY opens...it does NOT close it.is anything wrong with my car or is it optional? . . .any one?!?thanx
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
Buddy had a module from KPTechnologies that does it for the sunroof and the windows using the lock and unlock buttons on the key FOB. It's not standard. Google KP Technologies.
Also I believe (and I haven't used it because I really don't care) is that if you are walking to your car and hold down the unlock button the windows will go down. To make them go back up you need to obviously have the windows down, put the key in the door and turn it until they go up[ all the way.
Memory is sketchy, someone correct me on this if need be.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
yeah the sunroof and windows going up and down from the fob is an aftermaket module a guy installed. you can roll down the windows with the fob if you unlock the car, then hold down unlock.
as for using the key:Quote »c To open the windows, turn the driver's doorkey toward the rear of the vehicle for longerthan 1 second after the door is unlocked.c To close the windows, turn the driver's doorkey toward the front of the vehicle for longerthan 1 second after the door is locked.[/quote] (taken from the manual)
edit: also from the manual in case your'e wondering: Quote »The door windows cannot be closed by using the keyfob.[/quote]
theboydiddy
THANX MAN..i mean, i knew how to roll it down with the key FOB but wasnt sure if you could roll it back up. also they key in the door i knew that as well...uhm..would be cool if you could have all these features standars..but im not paying just for that. i dont think it would be worthed.
